Vokera 20-80 Flowmatic
31 Jul 2005
Glasgow
Swithced boiler on no proplem then when there a demand for heat or hot water the burner comes no proplem but then the flmae in the burner starts to rise then fall very qucikly...thinking blocked air ports in burner or issues with flue...any ideas..i think it needs a good service.
just what i was thinking..burner preassure is good but there was alot of dust dirt around the fan to that was maken a noise so cleaned that it sounds no to bad now....thought maybe a restruction in the gas valve but burner preassure is good.
when I read the first post on this thread I though you were the owner of the boiler but it seems you are a "professional". You should register for the "combustion chamber", you will get all the advice you need there.
