I'm having an issue with the hot water on my boiler.
Water doesn't go hot when turn on the tap but will work if the CH is turned on first.
When I turn on the tap when the boiler is at rest, the pin comes out the diverter valve and makes the micro switch but the pin on the flow switch does NOT go in.
In CH mode the flow switch pin goes in and makes the micro switch, then if I turn the hot tap on the diverter pin makes the DWH microwitch and I get hot water.
Anyone know why the flow switch is not made when the asking for DHW.
Tried bleeding air from Hot water heat exchanger but didn't solve it
