Recently had the boiler serviced, got the diaphragm that switches the hot water on and off replaced at same time.
Shortly after this, it showed the 'blocked flue' red light, so got the engineer back, and he stripped it down, cleaned a few cobwebs and dead insects out of the flue, cleaned the venturi, and put it back together. We tested it before he left, and all seemed fine.
However, it's still tripping the blocked flue light, and shutting down. It seems to do this when the heating is running, and we draw hot water. We get one go at the hot water, and when we try the hot tap after that, it runs cold.
If I switch the heating circuit off, so that the boiler is in 'hot water only' mode, we get repeated hot water as much as we want, but then switch the heating circuit back on, and it seems to trip the blocked flue light at some point. Difficult to tell exactly when, as the boiler is in grd floor garage and all taps are first floor and above
Can anyone offer any useful suggestions as to where the trouble may lie? The engineer mumbled something at the last visit about it possibly being the control board, and I'm on the verge of ordering one. Is unplugging the board and replacing with a new one a reasonable DIY task, or should I get the engineer back to do it?
