need to pick brains here. i was told to go have a look at this job simple routine or so i thought. tenant said she had no heating but hot water fine. I checked the hot water fine Then i selected heating. The boiler fired as it should high modulation then low. the kettling sound appeared and the boiler shut off however no lock out after 5 mins restarted it did the same. the pump impeller was spinning. the house has just been re occupied after a house fire ( council house ) so i just checked to not look stupid the valves on the flow/return both open took them off and checked. so curiosity got to me n i changed the pump same thing still kettling. swapped the pump back and got a new heat xchanger (common fault when no pressure reducing valve fitted ) and put new thermistor in. still same thing. so now i was gettin frustrated so i took the hydraulic block completely checked all the flexy hoses the bypass valve was on its seating. so i thgought perhaps dhw flow switch stuck so i linked it out and still the same!! it is just like a one pipe convection. i just felt like crying any thoughts out there??
