Good Morning All.
In ch+dhw mode, when there is an initial call for heat the burner ignites without problem and heats for around five minutes or so. After this, the burner goes out with the pump continuing to circulate. The temperature at this point has risen to 60°C, with the system pressure at 2bar.
I've waited the obligatory three minutes in-built delay timer before re-ignition (although to my mind the burner shouldn't have gone out as the set temperature hadn't been reached) yet the boiler just sits there pumping the now cooling water around the radiators. Incidentally, under these conditions, a call for dhw energises the fulcrum arm and dhw micro switch yet the burner still doesn't ignite.
Switching the mode selector switch from ch+dhw to dhw only, then back again to ch+dhw (nine times out of ten) gets the boiler to re-ignite immediately.
I'd very much appreciate it if someone could point me in the direction of what to fix/replace.
Thanks in advance.
Antony
Thanks in advance.
Antony
