Vokera Excell 80SP not firing up - pcb issue?
11 Nov 2017
My Vokera Excell 80SP is not firing up, either for heating or hot water (the pilot light is on though). The fan is on low speed and stops when I turn on the hot tap but the pump does not appear to be powering up (as far as I can tell with this being the first ever time I've looked at a boiler pump!). Having done a bit of research on this forum it seems that this could be a PCB fault? Does this sound likely?
The fuse in my fuse board has not blown so I was hoping to check the fuse on the PCB before then calling out an engineer if that hasn't fixed it. However having taken off the main cover to the boiler I can't figure out how to access the PCB without breaking the plastic parts. It seems like the plastic panel with the boiler controls should flip down but I'm struggling to see how to do this and don't want to snap something! Any advice much appreciated!
Thanks,
Iain
your flow switch diaphragm housing is blocked and that is as far as we are allowed to tell you as it is gas work and the site rules prohibit us from telling you anything else
Are you SURE
I would advice you start looking for a new boiler as part that is needed is no longer available ( at least from my supplier)
