Hi all,
I recently installed the gasket service kit which also replaced the bobbin thing in the divertor valve. However after a month or two, it started screeching when water started to flow. I stripped down the divertor, cleaned everything and put it back together. All fine. Now after about 2 weeks its started making the screech again.
Can happen when the boiler starts up, with either hot water or heating action. Screeches for 1/2s or so. Defo seems related to the divertor as that was the only thing stripped and cleaned and the noise went away, although for less time than before.
Any ideas? Should I just replace the almost new bobin with another one?
James
James
