I have the above combi boiler, but I have NO hot water, NO central heating and it doesnt even fire up. Any pearls of wisdom would be greatly appreciated !!
Thanks for the tips.....most useful.
Manually switching microswitch turns heating on while the second microswitch located to the right of it turns heating off....is this correct ??
Also, cant get hot water to work unless I wedge a clothes peg !!! under the long arm of the fulcrum!
Also !! system now sounds like it's cooking popcorn......now I know that's not normal !!
