I have a Linea 24, the Temp tells me it's giving out water at 63 degrees, but is just luke warm. Can anyone help please.
I have had to change and clean the Heat Exchanger many times before, as in a hard water area, although not done for a year now. I think the water board have now added water softener?
The symptoms have been different from before. Then as there is a shortage of water in the heat exchanger the thermostat registers that the water is too hot and switched off, making the hot water go cold until it cools down.
On this occasion the temp stays at 63 and the water luke warm. Can someone tell me without to much guessing weather it would be another part:- Pump, thermostat. Or should I clean the exchanger again.
There was a bit of noise when running the hot tap for a few weeks. I put down to the pressure, as I had a leak following the last time I cleaned the h/e. water would leak from the valve at the back above the H/E.
please someone give me some good advice....
