Vokera linea 24
16 Oct 2006
London
Hi. My vokera linea 24 keeps giving me intermitant hot water. It runs hot for a little while then goes cold. Any ideas please.
As chris said its a Vokera Linea
Run the hot tap and watch the temperature reading on the front of the boiler.
As soon as the boiler cuts out turn off the hot tap quickly.
The temp reading on the boiler will change quickly, if it shows approx 90 deg then it is highly likely that you have a problem with your water to water heat exchanger. ;)
