Vokera Linea 28 - No hot water
10 Oct 2015
When I turn on the hot tap, the pump and burner seem to come on and there is warm water but then the pressure gauge shoots up past 3 and then the fail safe kicks in and the pressure falls and the error code 07 ("primary thermistor open circuit") flashes. The radiators do heat up but obviously not when the hot tap is turned on. Is it a case of replacing the hot water thermistor? Any suggestions would be much appreciated.
If you cannot understand what you have written, doubt a step be step help would help:eek:
Thank you for your tooth sucking response, it upped your post count if nothing else. :)
Well it's not gonna be the thermistor.
How competent a Diyer are you?
Don't have the boiler serviced/an engineer you use for repairs etc.
