Vokera Linea Error 01
11 Jul 2005
Leeds
Hello there,
I have a Vokera Linea that is trying to light but gets no pilot/gas and shows error 01. Does anyone have any idea, my children are starting to smell!!
Its quite likely that the gas valve has stuck. this is quite a common problem with theis boiler when the weather gets hot.
You need a CORGI registered engineer to change it if its stuck but he must set it up properly, not just bang it in and leave!
Read this quickly before Kev deletes it!
Tony
Glad to see that your childrens' sense of smell is developing normally :lol: :lol: :lol:
Heres the relevant bumf out of the manual so you have the official version
If during the ignition attempt period (10 secs
approx.) the boiler fails to light, the ignition
control circuit will go to lockout. This is indicated
by the status LED (14) flashing red
accompanied by a flashing error code 01
shown in the temperature indicator (15). The
gas valve is de-energised, but leaves the fan
and pump running for approximately 2 minutes
after lockout.
01: Failure to ignite (see 6.5.5). To re-set
turn mode selector switch to re-set position
for approximately 10 seconds, then
back to original position.
