Vokera Maxin 24e problems
23 Dec 2009
Yorkshire
I had a new ignition box fitted last year because it kept locking out and it's been OK since, until I began using the central heating this year. Now it just stops heating the water but doesn't lock out, and the pump keeps running. If I switch it off, it will start up again most times, though sometimes I need to wait 30 seconds or so. It has gradually got worse over the last two weeks, but will occasionally run for a couple of hours, though it's usually only 20 minutes or so. I thought it might be the ignition box again, but this evening it went off while I was in the shower. I assume the ignition box doesn't come into play while the shower is drawing water. Anyone know what the problem is so I can tell the plumber? I don't want him changing parts until it works and charging for all the parts that didn't need changing.
Vokera Maxin's are an easy to work on straightforward boiler cant imagine it will be hard to sort out !
You needing a heating engineer not a part changer.
I am sure there is a good flow chart in the manual. Your man should be competent enough to read it and be guided to faulty part. Part changing based on suspicion indicates lack of skill
Therein lies the problem, how do you find someone who knows what they are doing and are willing to diagnose rather than change parts? They all say plumbing and heating engineer on their card/van/advert. Going on recommendation doesn't always work, as I have already paid to find out.
Thanks for your replies.
While this is NOT the acid test, look for smaller Gas Safe number. Bear in mind, a wiz kid might have a large number but could know all about boilers.
Look at these pages, plenty competent guys here, some also like the Vokeras
I asked in here last time I had a problem but got no offers to come and look at the boiler, even though I gave my post code, which is WF6, just in case anyone is interested. :D
