vokera synergi low hot water flow
17 Oct 2008
Yorkshire
can anyone confirm problem with vokera synergi hot water flow poor flow switch on cold water inlet? same switch as other vokeras
poor flow is more likely to be caused by the restrictor after the flow switch.
are they the same restrictors as in the compact/options withe the o ring that gets squashed
sort of, same part but its the rubber o-ring that swells or gets blocked.
i cant remember exactly but i think its the same as a linea,if you follow the pipe after the flow switch, where the pipe enters the brass body is where the restrictor is.
