Is the above law true, where I work we have Been testing that theory On a kettle, but the Amps drop when taking mains voltage of 240 to 220 ?
I have to say this displays a truly scary lack of basic electrical knowledge.Is the above law true, where I work we have Been testing that theory On a kettle, but the Amps drop when taking mains voltage of 240 to 220 ?
You've only quoted part of the "theory(?)".
It should be:
"To maintain the same power output, if the voltage drops then the current must increase". Useful for (say) cable size calculations; look at the large wires to your car headlamps; with 12V they need about 5 amps each, whereas a 240V lamp of the same power would only need about one quarter of one amp and a smaller wire. The voltage is pressure and your kettle or headlamp bulb is a fixed resistance, so, as you lower the pressure less electric current (amps) will get pushed through the kettle or bulb and the power output is reduced. You can easily see this with the headlamp bulb when the car battery needs charging as the bulbs will be dim.
I`m not sure I would really call that `negative resistance` in the usual sense, but it`s certainly true - as you say, due to )ften irreversible) `state changes`. Ultimately, of course, sufficient electrical current though any biological tissue will turn it into carbon, a pretty conductive material! However, that`s a very irreversible process (turning lumps of carbon back into a human being would get you a Nobel Prize!), so not really `negative resistance`!One other notable widespread 'device' that also can exhibit negative resistance is the human body. Wet salty bags of Spoo that we are, if we're unlucky enough to establish a current path between that inquisitive finger and our club foot then the resistance of that path can fall as the current flows due to chemical changes.
I can't believe this is even being discussed again![]()
Nooooooooooooooooooooooooooooooooo
What have you done![]()
When it's just a conceptual discussion (rather than some practical issue which one hopes was solved months or years ago), I see no harm in someone 'resurrecting' it if they feel so inclinedI can't believe this is even being discussed again![]()
I agree. Some others won't.Very much so John. If it's a new problem then it's thinking cap on and best neuron forward to help out. But my resurrecting post was aimed at provoking thought with the OP or those who may pass by in the future. The OP sounded like somebody who may be studying or learning. And since constant power had been done I added my 2pennith. ... So there you have it; in these days of green living and austerity measures, another thread that's been further used, topped up with fresh characters, when it could of so easily been consigned to the bin.
