Volvo 940 ABS lamp lit.
26 Jun 2004
London
What are the most common causes of a continually illuminated ABS warning lamp on this model please?
tony
Is it not also a low (worn) brake pad warning light?
Have you replaced your brake pads with genuine Volvo parts or "inexpensive" pads from your local trader?? :?
What is the manu. year and engine capacity Tony?
Are you able to read the trouble codes? At the back of the engine bay (iirc RHS) there may be two diagnostic units (only on certain age models though). If so, on diagnostic box A plug flylead to posn 3. Turn ign on. Press and hold the button on diag box for 1sec. The fault sequence will return as a sequence of flashes on the diagnostic unit LED separated by a few seconds gap, i.e. two flashes, gap, three flashes, gap, two flashes = 232. Press the button again for next trouble code.
dont bother responding to tonys posts he doesnt follow them up
