Thanks for your comment. This makes sense, I understand why you would go for the third option "thermost." if it can't modulate down that low.
I have a small ecotec plus 824 combi, which apparently has a modulation range of 1:6. = 16%.. Another site states an output of 6.7 to 19kW. (I can't really work out how that corresponds to 16%, but all the same). So, it looks like the "modulation" should be a good setting for me?
In hindsight, I should have gone for a larger boiler. Its medium sized house, which I'll make bigger soon, and its old with limited opportunity for thermal upgrades to the fabric, and single glazing I'm not likely to be able to get changed. Sorry to say my heating engineer was not forthcoming with guidance on boiler size, and I had to push him to fit the weather compensator unit at all. He had not fitted one before and was jittery about it, thought it was rubbish. The boiler deal he originally purchased came with the on boiler standard control unit, and when I reminded him I'd asked for the weather compensator he just added the cost of the unit (delivered 3 days later) and would not omit the extra over cost of the standard unit (which he kept for another job). On the plus side, I can't fault his pipe work and he took pride in his joints and pipe alignment. He just likes to stick to what he knows I guess. Anyway enough moaning already, its boring.
Also I've learnt a lot about boilers, modulation, efficiency and heat curves. Its all pretty interesting I think.
