VW Caddy 07 plate
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
The coolant antifreeze is pink in colour.
Can one of you learned chaps recommend what I can add to the coolant for better freeze protection
thank you
DP
Usually the VW antifreeze requirement is imprinted on the cap of the expansion bottle......G12 or G13 - pinkish or purple in colour.
Its life is around 6 years for anti corrosion, antifreeze properties longer.
The coolant concentration can be measured with the appropriate tester, and its recommended you use a 50% concentrate / water mix.
John :)
The pink colour tells you what type of anti-freeze it is.
That link confuses me more than it helps!
"These days, there’s no real reason for a coolant manufacturer to use a certain colour, so it’s not easy for you to know what chemicals are in the coolant just by seeing whether it’s blue, green, yellow or orange".
  • Thanks
Reactions: DP
That'll be because they want you to buy their one.
