Wall hung toilet with soil pipe back through wall
  • Thread starter Thread starter bsr
  • Start date Start date
bsr
5 Aug 2008
Gloucestershire
Hi
I'm looking at a new bathroom. Part of the ask is a wall hung toilet. Currently the soil pipe goes straight through the wall at 180mm height (centre). Do any of the frames support a back exit? The videos I've seen are all side or bottom exit.
I was thinking of replacing the provided waste components with a Flexi?
I think (guessing) the 90 degree pan to soil pipe in the photos you are looking at are all for illustration. You can get plenty of wall frames that will do what you want. Its also very easy to build your own.
You can get geberit adaptors for straight out the back. Your issue being frame pan WC outlets are generally higher than the standard 180mm
  • Thanks
Reactions: bsr
My wall hung frame supported a through wall waste pipe.
It was an Oli.
I can't remember the model number. I went for the thinnest (least deep) one. The upside is that the whole frame is taller, meaning that you can press the flush plates without needing to put the seat down.
Pin5 thanks. Any idea of the typical height? The ones I've looked at are 220-230mm. And would using a Flexi work to lose the 40mm?
Personaly wouldn't used a Flexi plus the part where it clamps onto the frame is 90mm pipe size.
