Good Afternoon All,
I'm looking to extend my house to the rear, the main house is solid wall, and at some point in the future i will be adding external wall insulation.
As part of the rear extension build, i will have a cavity, the question is, should i build the exterior wall in line with the existing wall, with the cavity coming into the extension volume, Then add external insulation as i do the rest of the house to keep it a straight flat wall?
I understand adding more insulation will reduce energy/heat loss, are there any down sides? the once outside wall of the cavity will now be insulated once, the inside wall will be insulated twice. Any ideas on moisture issues?
Also, if i am looking to do this, any issues with me building both the inner and outer walls in thermal or otherwise blocks?
Alternatively, should i just insulate the cavity, and leave it stepped once the external wall insulation is applied to the rest of the house?
