Right, a few years ago i boarded over an alcove and built a framework to contain recesses for my entertainment equipment (in my bedroom).
I built the framework out of 2x2 sawn timber, built 2 identical frames front and back. Each joint is made using two 2 inch screws recessed halfway through one piece, so one inch goes into the end grain of the other piece. Basically its going nowhere and I dont want it to. Faced with chipboard.
However, I recently bought a 32inch LCD TV! Which is too big to sit in the recess, and obviously being a VESA mount, wont fix to the framework currently there (I want it centred on where the TV sits now). I actually modelled the recess on my parent's old 24 inch toshiba CRT, as I didn't have a TV when I built it! That TV there is a 21 inch.
The new TV will also foul the speaker frames that I made out of some bits of timber with black cloth stapled on.
What I'm thinking is I add a bit of framework across the TV recess, then face over the lot with some thin MDF, drilling small holes for speaker wire, and surface mounting the speakers. Its currently emulsioned chipboard. This would give the "sleek, clean" look i'm after. I have attached some pictures so you can see what i'm dealing with! Any advice welcomed!
The TV and speaker recesses:
(the TV recess is fully enclosed with 15mm chipboard, apart from the front, obviously)
The speaker recess with no cover on (the covers simply have 2 screws in them, which hook into holes on the front here). You can see the 2x2 framework here.
A view of the whole front. The lower recess is also fully enclosed. Both recesses have ample provision for power and aerial downleads!
The bottom of the framework here. I just fitted a shelf here, couldn't think how to finish it off. Any suggestions? This also provides access for someone laying on their back to access the back of the unit (there's about a foot between the back and the wall, total depth about 3 foot)
You might be able to tell, i've recently decorated. Took down picture rails (which I even stuck to this unit when i built it!) and had the walls plastered. So to remove any of this unit would probably take plaster off with it too. Hence the total face-over idea. Also the adjoining wall to the right is about 4mm proud of this unit due to new plaster.
