Hi All,
I'm installing a catnic style lintel over a new door opening in the gable end of my house and I'd be grateful for some help:
1. I need to fit a d.p.c. over the lintel. What happens with the dpc at each end of the lintel ? Do I just cut it flush with the end or run it into the brickwork either side by 100mm or cut it short or something else ?
2. Some of the wall ties will be lost when I cut the new door opening. Do these need to be replaced, say, either side of the new door opening, level with the original tie positons ?
3. Lastly, what do I do to the exposed cavity around the new opening ? Is there an insulated piece of trim I can push in and render straight over for make the reveals ?
All advice very gratefully received.
Thanks,
P.J.
Thanks,
P.J.
