Wall Vent - Can it be replaced?
13 Jan 2013
Hampshire
We've recently moved house, into one that was built in the 50s and from the state of some of it hasn't been touched since!
Apart from i should add - cavity wall insulation, and double glazing ;)
We're about to kick on with some of the works on it, and we have two of these vents (see below) in an external wall where the stairs are.. these are incredibly flimsy but mainly large (bigger than a dinner plate) that are basically a whole to the outside world..
What i want to know is..
1. What on earth are they for, and why does a hall way need so much ventilation?
2. Can they be blocked up, as they let a lot of heat escape? - Who should i talk to re: this, assume builder?
3. If not blocked up, can a more efficient vent be placed over them in order keep heat in better?
4. If they are / were blocked up, is there a ventilation mechanism that is more modern that can be implemented?
Thanks,
Chris
There are number of reason or possibilities.
In older houses vents were installed to prevent musty smells, also if open fired or gas appliance where installed then they would be used to create free air for combustion and air change purposes. There is also a possibility the vents have been formed when gas wall heaters have been removed, instead of infilling the hole.
If you are having new central heating and the wall cavity insulated and they are not required to provide free air for gas appliances, then yes they can be blocked up. A builder as you quite rightly say would be best person to approach.
As above, they can be blocked up
I don't think you will require ventilation.
@PrenticeBoyofDerry - excellent, these were all the answers i was hoping for... based on what i hope are sensible assumptions re: their original use that you seem to have come to the same conclusion on.
i shall commence the telephoning of builders for quotes... fingers crossed only a few hundred squids.
Ty.
In my parents 1930s semi, the area under the stairs was the larder and had these vents with a zinc mesh over them.
Frank
Frank
yeah we also have this too (in the kitchen which kind of back onto an 'under-the-stairs' bit)
when we refit the kitchen that is going to turn back into a larder, but a funky modern one without the massive vent ;)
