I have a problem with the bedroom wall in my house. I live on a corner house the two outer walls of my bedroom are always cold. I wall papered twice in the room and after about 12 months of repapering the paper starts peeling off. Marks tend to appear on the paper and when you touch the paper is like as if its damp. I am fed up with it. I have been told its not rising damp. my pointing outside is fine so its not water penetrating through the walls.what i have found is that someone at some point has painted the walls with gloss paint so not sure it this is causing some problems. but if this was the case all walls would be affected and they aren't. someone has recommended i use Anderton three in one foil backed paper and then either paper over this or paint. Would really appreciate some advise or if anyone has used this foil paper has it worked.
