having painfully learnt how to wall paper from scratch this year i am now looking upon each finished room with praise, however in the rooms i have plaster coving which is not 100% straight or for that matter the walls are not straight either understandably so, my question is i have an electric wallpaper cutter which cuts paper great by the skirting board ,but used by the coving it is poor beacuse of the way the coving is laid.
I have had to cut the paper with decorators scissors with the paper just covering the bottom of the coving 2mm or so,but this is hit and miss .
Seems a simple quesion but is there a proffessional way of getting a clean constant wallpaper cut against the coving so that it looks smart and not amateurish and shoddy when you look up close to it? Should the wallpaper be papered under the coving or should it cover the bottom of it just slightly 2mm or so.?
Cheers chops
Cheers chops
