Wallpapering - lining paper then paint - good way to go?
  • Thread starter Thread starter k4p
  • Start date Start date
k4p
4 Jun 2010
Bradford
Hi all,
I plan to wall paper a room. Most other rooms have been plastered and then painted.
The walls aren't perfectly smooth.
I plan to use lining paper and then paint - hopefully to get a nice finish...similar to plaster and paint (i know it won't be as good as a plaster paint finish).
Any advice?
e.g. type of paper (grade)
When I've done it in the past, I've cross lined with 1000 gauge lining paper, which was then lightly sanded down to remove any grit missed when stripping the walls; and then hung fine lining paper vertically as normal. This provided a pretty good surface for emulsioning over.
My advice would be to sand down the walls by hand using wet and dry sand paper nd a bucket of water, then take time to fill all the cracks and holes in the wall using pollyfilla, when dry sand down all ur filling and skim over it again and then sand down the walls once more using normal sand paper. Now you can cross line the walls (horizontal) using 1000 grade lining paper.
This may take alot of time but preparation is 90% of decoration and this will give u the nearest thing to a plaster finish.
I'm not sure it will end up being less work than sorting the walls :?
