Walls lights
7 Jan 2011
North
Ireland
Hi
At weekend past my wall lights started flickering out of the blue.
I thought maybe was a bulb so changed all lights still the same.
I then replaced the dimmer switch still the same.
Any ideas??
Flickering normally means the bulb and the switch are reacting with each other, although could just as easy be a bad connection, step one fit a non dimmer switch even if just temporary and see if flicker stops.
If not it points to loose wire, likely due to vibration, so likely where wall lights connect to the supply. But get rid of dimmer first.
