Hi folks,
My radiators are getting warm when hot water is in use. Heating is off both at the control and on the boiler but the issue remains.
I have done some research already which points me to:
a)- Divertor Valve Switch
b)- Divertor Valve Cartridge
Am I right? I have also foind some threads pointing to the heat exchanger but then symptoms of that are different.
Please can someone advise If I am on the right path before starting the repair and parts ordered?
I was thinking of the following steps?
1-Turn the electric off
2-Turn the gas off
3-Turn the mains water off
4- Drain the heating system (understand this step may not be required if it is just the divertor switch)
5- Replace divertor valve cartridge
6-turn everything on and pressurise the system.
Please can someone point me at the right direction? Also advise where is the best place to get parts
Boiler is Ideal Vogue C40
2-Turn the gas off
