Hi All,
I am building my first warm roof construction that doesn't have brick and wall plate past the insulation. I am wondering the common way of creating mounting points for the fascia on the edge of the 120mm insulation, do you run wood all the way around the perimeter of the insulation built up to the 120mm height or is there a more cost effective way like making mounts every 600 centres instead, or even cheaper EPDM covering the whole edge also??
