Hello, I own a Siemens SN65M086EU/43 dishwasher that, unfortunately, has recently stopped completing its wash programs correctly.
It all started when, every other wash, it wouldn't dry, leaving me with dripping dishes.
The problem gradually worsened, and sometimes it wouldn't even drain the water after a wash.
In recent weeks, the problem has gotten worse, and sometimes the program stops after just 10 minutes.
Sometimes, even 5 hours after starting, when I open the door to check the remaining time, the display still shows 1:28 remaining. Essentially, the timer remains stuck, and I have to reset it manually.
I tried running the cycles with a different circuit board, and the results were the same.
I'm wondering if the door lock sensor is faulty and could be causing these symptoms.
I should point out that the display never gave me a single error code, and in fact I was wondering what the key combination was to enter diagnostic mode.
A word of advice is greatly appreciated. Thanks, regards.
