Washer between tap and top of basin?
13 Aug 2007
Just get a set of 2 taps for our bathroom sink. When I fit our kitchen tap the fitting was like this:
Tap
Washer
Sink
Washer
Nut
But with these new bathroom taps I've got there's no washer supplied to go between the tap and the top of the basin:
Tap
Basin
Washer
Nut
Does this sound right? What's to stop water seeping in between the tap and the basin because without a washer the joint can't be water tight? The instructions show the diagram as above without a washer.
has the tap not got a rubber o ring that fits into a groove on the base of tap.
which stops you having tap straight on to the ceramic and cracking basin when tightening.
if not use a clear silicone on base of tap fit into place tighten then wipe excess of the basin.
No O ring on the base of the tap.
instead of silicone couldn't I buy a washer too?
