Washing machine standpipe trap under floorboards, is it possible?
11 Jan 2012
London
Hi, I come across a kitchen design that doesn't give much room for manoeuvre and I have to run the new washing machine waste under the floorboards.
Rather than use a conventional standpipe and trap with compression fittings, can I build my own with solvent weld fittings so to have no chance (or should I say less chance) of a leak?
Of course you could but a trap isn't just for the water seal, it is so it can also be cleaned if and when needed. That needs to be kept in mind.
I know, but being under the floor it will never be accessed directly.
If needed to be cleaned it would have to be rodded.
Why don't you think you can have a trap above the floor?
Because there's a brick step in the wall behind the wm and space just for a standpipe in a corner, but not for the trap.
I don't want to start breaking walls as i'm sure it would uncover more trouble.
I thought that maybe I could do the standpipe and trap with 50mm weld pipes so to avoid any potential blockage and make rodding easier if needed.
What do you think?
How about a Hep V O waterless "trap" in the upstand part just above the floor ?
Didn't think of that.
Thanks.
It will work a treat.
I'll go for this one:
You'll need a Mc Alpine 40mmT31U to adapt the threaded end so both ends go onto pipe. Product code 72306. Job's a good un (y) PS when you do the pipework use swept bends - not those **** 90 degree things that can catch debris
Definitely.
Done quite a lot of plumbing labouring and stole lots of secrets. (y)
