Washing machine stops part way thorugh cycle
29 Aug 2007
Buckinghamshire
I have a hotpoint aquarius WD440 washer dryer which stops part way through the cycle. It takes on water, turns the drum but then gets to the rinse part of the cycle and just stops, the lights are still on as if it is going but the drum no longer turns.
I'm not getting any flashing light error codes. Anyone got any ideas what is wrong with it?
Rinse valve poss open circuit ,put on rinse cycle does it fill
It does fill with water but it appears it doesn't drain. I'm guessing its either a blockage or the drain pump is knackered. I replaced the drain pump about 15 months ago so hoping its not that.
