Waste water pipe along back of electric cooker
19 Feb 2015
Would it be possible to configure appliances as shown in the schematic below so that the waste flow pipe from a dish washer and a kitchen sink can travel along the back of an electric cooker?
I had a look on Curry's website looking at the sideview of multiple electric cookers and from what I can see electric cookers are all flush to the back wall.
There would be no issue with water supply pipes as supply would meet sink first, then dishwasher.
Free standing cooker ? Then no .
Solid floor ? Or runs under floor boards?
It's a free standing cooker, but perhaps it's possible then with a built-in oven?
It's a floor board floor with joists running parallel with the direction of waste.
and run from sink to outlet at wall would be 3.7 metres.
Built in oven has large void to rear at low level to run waste . DW presents more of a problem but again low level drainage possible .
Sink between appliances would be better is layout allows .
built-in dishwasher would be an option too
Same problem with built in DW, low level drainage required under DW legs to rear.Oven problem depends on its size, design. Have a 900mm freestanding cooker which sits on 150mm legs while smaller ovens often do not to have legs as they are more unstable.You can increase worktop width to a 650mm wide top which then would give extra 50mm at rear for waste etc.Other options but depending on wall construction.
So that would be Oven, Sink, DW.
(instead of Oven, DW, Sink).
Out of curiosity, in what way would this be better? Perhaps as outlet at back of DW is higher than that of sink?
Only one appliance to get the waste passed, DW empties to sink waste .
Also has advantage of sink being in easy reach of cooker , this is the setup in my own kitchen .
