Good Morning All,
I bought a new wooden garage (effectively a big shed!) before Christmas and it was fitted in late December.
In order to have it fitted, I did a lot of digging out at the back of my house and had a concrete base poured. The work was done while I was away and unfortunately was not as I had ask for. I wanted a base, a gap of earth and then a retaining wall for my lawn. What I got was a base poured and the wall build on it at the edges. My builder and I had clearly had a misunderstanding but he knocked a few quid off as I wasn't happy. To be fair, the work that has been done is good quality and I have used him again (just with triple clarification of everything asked of him!)
Anyway, this leads to the cause of my issue. The garage was fitted and bolted to the concrete. There is a 1-2 inch gap on each side between the outer wall of the garage and the retaining wall. Rain water can get down there and then seep between the garage and concrete base. The wooden construction is such that there is effectively a 2 inch / 5cm lip / step all the way around inside the garage. This is all hopefully shown on the diagram below:
I have tried remedying the issue as much as possible with guttering either side and attaching / gluing thick wooden battoning between the retaining wall and garage to cover the gap. Finally I put down a 'join' of Wickes Liquid Damp Proof Membrane (as shown in the diagram) between the concrete and the wood panel base.
I was hopeful that the combination would help to abate the water coming in. It has helped a bit but after rain for most of yesterday, water is still coming in under the DPM and diluting it. I'm sure the DPM is not the ideal solution but I was hopeful it would work for this application. Perhaps in this temperature it will take a lot longer than 16 hours to dry/cure?? It was put down on Saturday and it didn't rain again until Sunday p.m.... Does anyone have any thoughts?
Hopefully someone has some suggestions / ideas how I can cheaply remedy this? I don’t really want to go down the route of pouring a concrete screed inside the garage up to the 5cm lip height (assuming even that would work as the water would hopefully not climb the lip!). The only other thought I had was to lay an edging of concrete mortar around the base to plug it....?
Sorry for the novel above! Hopefully someone out there might have an idea (starting to wish I'd just gone fore a brick built one now!)
Kieran
Kieran
