- Joined
- 12 May 2007
- Messages
- 292
- Reaction score
- 2
- Country
I noticed the water filter stopped working, traced it back to the self piercing valve the guy installed when fitting the filter / water softener / kitchen, seems the valve is clogged with scale or something so I have plugged this off.The only other place I can tee off from the mains is below the isolation valve for the inlet to the water softener, from this tee I can then feed the water filter, problem is the pipework has a 15mm female connector going to isolation valve, on the other end of the valve is the 3/4 hose connector going to the softener. What I need is a 15mm tee piece with male 1 end and female the other, will stick a 15mm x 1/4" push fit connector on the tee, is their such a beast as a 15mm Tee with male / female connections, maybe need to buy in chrome rather than copper ???
