I recently had to flush the CH system due to a leaking valve which needed to be replaced. I had the boiler serviced at the same time.
Since the system has been refilled and radiators balanced I experience an intermiitted thunderous bubbling sound coming from the loft.
It looks like the water in the CH filling tank is getting hot, bubbling over and in some cases the loft is becoming full of steam.
The CH folk claim it must be air in the system and have fitted an automatic air valve. They also changed the pump just in case.
Guess what.. same problem.
My system has two motorised valves , I notice that when the "thunder occurs", the CH is invaribaly not demanding heat and the hot water is demanding. Turning up the room stat, causes the the CH valve to open and the "thunder" stops shortly after. I also hear air hissing from the automatic valve at the same point.
Question:
Is this likely due to an airlock or is the problem due to the "heating water" actually boiling ?
If it's an airlock, why does it seem to appear only when water is being heated.
Could the problem be due to the Boiler thermostat, ie boiler not shutting off when it reaches temp ?
Any ideas much appreciated
Question:
