I noticed a few weeks ago getting less hot water from the kitchen and bathroom taps than usual. The problem has gotten worse until now there is no hot water from any hot water tap only cold regardless of how long the central heating is on. When I started checking pipes in the house to see if there was a leak anywhere I did not find water leaking from any pipe but could hear water running in the pipes even when all taps and the CH were off. After turning off the supply from the attic storage tank the noise of running water stopped.
The only under floor pipes in the hot water system are the supply to the boiler and the supply from the hot water cylinder to the kitchen sink. The radiators are still toasty warm but no hot water from either the kitchen or bathroom taps.
I suspect the problem is in the supply to the tap as the radiators are ok, but before I start digging up floors can anyone suggest where I should start looking? The supply to the boiler to the kitchen tap?
