Water leaking from lead lined overhead toilet cistern
17 Nov 2006
Sheffield
We have an antique overhead toilet cistern which is a wooden box lined with lead.
Arrived home yesterday to find a leak in one corner. We've emptied the cistern and have noticed that the lead in that corner is a lot paler than the rest. Does this mean it is becoming porous/coroded?
Any suggestions on how to fix it much appreciated.
"Does this mean it is becoming porous/coroded? "
Very possibly.
If you have time and enthusiasm to preserve/restore this antique you could
1 clean and degrease the suspect area and smear it up with clear silicone or
Fernox LS-X "the ugly bodge" might well work if done carefully
2 line the tank internally with fibreglass/resin
3 use plumbers metal (not really a Diy job unless you've wiped lead before)
4 give the tank to a specialist leadworker - these days a roofer- for repair
In all cases take the cistern off the wall and work/test on the bench!
There is an easier and quicker repair!
Buy some water based brush on bitumen paint as designed to waterproof brickwork.
Make the room warm with a fan heater perhaps and brush on a full coat all over. It does not need careful drying first as its water based,
Then when it has mostly dried, brush a second coat over the suspect area and ideally repeat that a few times.
When its completely dry, thats important, the refill and use for the next 10 years!
Tony
