water marks on a plastered wall (skum marks)
6 Oct 2009
Plymouth
high all fellow plasterers i have a small question is it acceptable to have a few water marks or skum marks please let me no. and if there will be any problems with it thanks peeps
Try to use the minimum amount of water when you polish up..
Too much water as Roy says. It breaks down the surface into a mush (your scum marks) & this collects in minor hollows leaving a powdery surface when dry. When removed (don’t paint over it), it makes the hollows more pronounced & leaves the plaster grain exposed underneath which looks a bit like suede brushed against the grain when painted; it may need local filling & will take more coats of paint to cover up.
A guide to my personal water use; I don’t use a brush & prefer an old 750cl kitchen spray bottle as I find it gives more control. A full bottle will easily do me an average size room (say 10 x 12) with some left over! Don’t use additional water until you really have to & then as little as possible; & donlt over polish the surface, it's not necessary & only make it more difficult to get the paint to stick. :wink:
