I've just moved house and have noticed that every time I turn on a hot water tap the pressure will drop after about 30 seconds to a trickle so I have to open the tap more. this will happen a further two times before it settles into a steady flow. MY boiler is a combination Baxi Potterton Performa 24 eco He, and is about two months old, or so I was told by the previous owners. Also the water will sometimes turn cold for a minute before returning to normal temperature, this happens after its been running for few minutes. The pressure hasn't dropped any and I've checked every radiator for leaks although I guess there wouldn't be any if the pressure is not dropping.
Anyone have any idea what might be causing this?[/b]
