water pressure on ideal Isar system ???
8 Jan 2010
Liverpool
I have noticed that the water pressure on my boiler system has fallen below 1 bar. How do I increase the pressure? I don't have the manual for the boiler as the people I bought the house off didn't leave it.
I knew how to do this on my old boiler but the fitting aren't the same and I can't see how to do this on my boiler.
please help!
Underneath your boiler there should be a flexible filling loop pipe connected to a small tap on the cold water supply. Sometimes the pipe is left in place, some people remove it and only connect it to top up the system. When the pipe is in place open the tap slowly and watch the pressure on the guage. If pressure is falling there may be a problem. Also watch pressure guage when central heating has been on a while, it should be 2 to 2 1/2 bar max.
no it shouldn't - 1.5 to 2 bar when hot or 1 to 1.5 when cold
pressurising this boiler to over 2 bar is asking for problems
thanks for the replies :D
My boiler doesn't have the flexi pipe or anything that looks like it could be a pressure release valve.
any advice?
It's an ideal isar HE30 if that helps.
Have a look around, possibly in airing cupboard. You have a pressurised system, the only method of getting water into it is via a filling loop as described. Normal practice is to put it under the boiler but some can be hidden!
Strictly speaking, the braided hose should be removed from the valves when not being used to fill the system. If you have two valves, close together, near the boiler, one will be on the cold water pipe, the other on one of the larger heating pipes, then its possible the hose has been removed. You will either need to locate it or purchase a replacement.
look out for a warmsure van and ask them,hopefully they will do it for free,there's plenty of vans in liverpool
