Over the past few days the water from all our cold taps has started running cloudy.
Things of note:
It used to run cloudy just after you turned the tap on and then ran clear a few seconds after.
About two weeks ago a plumber changed the cold water over in our flat from tank fed to mains fed (the kitchen sink was always mains fed)
They all now run cloudy constantly.
A week ago i turned the cold water supply off and ran the hot water tank dry as I needed to change the hot and cold taps in the bath. Once I had done this and turned the water back on the hot water wasn't running properly presumably due to an airlock so I used a hose to flush the hot water system using the cold.
Any ideas as to why all my water is now cloudy and do i need to do anything about it?
Things of note:
