Water Softeners for a 5 bathroom house
25 Aug 2010
London
HI there, I am new to the site and i hope I can get some much needed advice.
I am renovating a very old house, so new plumbing system throughout. The house has 5 bathrooms, 1 in the gf, 3 shower rooms on the ff plus laundry room and a master bathroom up in the loft. We are installing a megaflow system and want to invest in a water softener. Can anyone advise which type we should go for and what the limitations are in terms of maintaining the water pressure? We have had 2 quotes from 2 different companies but their quote varies by over 1K and we can't figure out who to believe? thank you
Go for one that regenerates itself based on water meterage/usage and not one that regenerates 'come what may' every night.
Size of water connections and flow rate capabilty are important for a softener used on a megaflow or similar unvented hot water system. Probably need to upgrade the inlet and outlet hoses to 22mm minimum.
Keep a drinking water tap, ie un-softened water, in the kitchen and maybe in the bathrooms to provide drinking water that doesn't taste yucky.
Ease of reloading the salt and location/ease of access is also important if those doing it can't handle 'gurt big sacks' of salt tablets.
Other than that you pays your money and takes your choice!
Thank you Tipper!
There will be a separate filtered water tap on the kitchen sink. I guess the water filterer will be filtering "soft" water....is that OK? Or will it still taste funny?
Best to have kitchen drinking water tap direct off the mains.
The softener tries to remove calcium and mag salts.
They are good for health as well as making the water taste good.
