You state that the oversite is 76cm from the floorboards.
That's a lot of void to fill, you can't just fill it up, it will all need to be compacted in layers as you go.
A block and beam floor might be a better option, but if your existing joists are ok and the void remains ventilated, then insulating between them would be a lot less work. Although you should liberally apply some wood preservative to the timber whilst the boards are up.
