links?
http://science.howstuffworks.com/environmental/earth/geophysics/question473.htm
http://en.wikipedia.org/wiki/Current_sea_level_rise
http://www.scientificamerican.com/article.cfm?id=arctic-ice-melts-cause-rising-sea
seems there is some truth in what everybody has posted![]()
No. Only in what the Mighty Joe-90 has written.![]()
There must be some calculations that show how much sea levels would rise if joe went swimming with his huge brain (and thus head) displacing so much sea water![]()
Is the hose pipe ban still in force after the wettest April in over a hundred years.The wettest drought on record?
A wet April doesn't compensate for two dry winters.
Rain water as it happens CAN be used directly to provide for the water supplies. We have reservoirs where it is illegal to swim , fish or boat because the water goes directly into the public supply without being treated. (gotta love the fish poo though..)
Reservoirs were located in positions where the catchment received little or no disturbance, thus the quality of water supplied was often wholly acceptable without the need for either filtration or disinfection. As public hygiene standards evolved, many of these supplies were improved with the provision of chlorination systems. The regulation of water quality ensures that all supplies are now provided with full treatment, including coagulation and filtration.
In England and Wales, two-thirds of drinking water comes from surface water, including reservoirs, lakes and rivers, and the rest from groundwaters. There are also areas that receive water from a mixture of sources.
Water is treated at water treatment works before flowing through water mains, sometimes over considerable distances, to arrive at the tap. Samples are taken at each stage of treatment and distribution along the way and tested by the water company to make sure that the customer receives high-quality water.
"All bar one of the top 10 warmest years on record have occurred since 1997 and all the UK's top seven warmest years happened in the past decade."
Quite wrong Joe. If the Arctic ice cap was to completely melt tomorrow, the seas would actually go down. Water expands when frozen. As the North Pole is actually frozen sea, it would cause the waters to recede across the world...... Now,, if the Antarctic ice was to melt then sea levels would indeed rise, as this body of ice is sitting on top of land. So all we have to do is build extremely large freezer plants in Antarctica to keep it frozen... End of problem.Oh and we are only talking a couple of degrees per hundred years. You won't notice the heat differential but the balance is upset and ice caps melt and seas rise and El Nino causes chaos.
I've already told him that.
You assume I can be a***d to read the entire thread![]()
