I'm going to install a wetroom inot an old cupboard and can't picture how the door will end up being watertight. How are doors typically setup for wetrooms to be waterproof?
wet rooms dont have doors as such
they have a large area away from the shower for it to turn into a normal room with the surface water shed into a drain
so wet area the drying area draining toward the shower then flat normal area where you could have a door because its like a normal bathroom
After having a sore left big toe two weeks ago, I am having rather less 13-14% red wine and less red meat.
Tonight, I had a Rheinhessen 8.5% Spatlese and as thats now finished I am having a little vermooth until I turn in ( I nearly said pass out ). As I came out of the store, I was approached by someone who works in a parts shop who saw my Agile Services " I love boilers" tee shirt. I had actually met him before at his shop.
I must remember to introduce him to one of my customers who is looking for a desi date.
I looked at a smaller house for sale which had two bedrooms and a wet room about 2 x 3 m and I was wondering what the vendor used his wet room for.
The cupboard's about 5 foot by 3 foot - so not big enough to make into a conventional wetroom, more a showerroom, but as I don't want to just put a small standard shower cubicle into it, I was looking to get it all waterproofed like a wetroom then tied floor to ceiling. It's just the door I can't get my head around...
You could try building a small step-over wall at the room threshold, say 100-150mm high by 100mm width. You could then tile this on the wetroom side and the top. This would stop any surface water leaving the room. Then fit the door on the wetroom side so that when closed it butts against this wall but goes down to floor level.
