WB greenstar CDi- is this a fault code?
16 Apr 2008
Bedfordshire
Turned the boiler on for heat for the first time since a boiler service which seemed more of a safety check and nothing else.
Boiler took maybe 20 minutes to get from 37C to 65C with the temperature alternating between the temperature and the photo shown. Anyone got a theory why it took so long to get to temperature? This event happened after I called for heat and then straight away my son took a shower. The 20 minute lag occurred after the shower was turned off as I know the heating shuts down on taking a shower.
This is what they call siphon fill mode. It will do it every time the boiler is switched off. It will resume normal service after around 15 mins.
as already advised , not a fault code and nothing to worry about, will happen every time power is switched off to the boiler
