We had a problem with our boiler in February this year whereby no hot water was delivered when demanded (CH is fine - never been a problem). WB engineer came out and fitted a new flow switch and solved the problem. Everything has been fine since then.
Two weeks ago, the same problem occurred. Engineer came out and fitted a new flow switch. Problem solved.
Four days after this, the problem came back again. WB sent two engineers out who spent five hours trying to solve the problem. They couldn't. They suggested it could be our mixer shower allowing cold water to flow into the hot.
So...we got a plumber out to install a brand new mixer shower and fit a non-return valve to it. We still have no hot water.
WB are saying it's definitely not a problem with the boiler. I'm at the end of my tether. Nothing has changed in our flat, i.e. no new appliances, plumbing etc, and up to things going wrong, we were getting hot water.
Can anyone help? In my opinion if we're not getting hot water, it's a boiler problem if nothing else in the flat has changed and we've got a brand new shower fitted.
Please help!
Please help!
