Hello all,
I have an ongoing problem with recurrent airlocks of all HW in traditional gravity fed indirect/open vented cylinder system.
My previous posts below refer (hope these show correctly):
http://www.diynot.com/forums/viewtopic.php?t=22341
http://www.diynot.com/forums/viewtopic.php?t=22196
Plumber called twice last week to look at airlock problem and can't understand it. He checked system - pipe outlet from top of HW cylinder full of air, hence no water flow. He drained system down/refilled it. It filled quickly and seemed OK. He checked loft tank - filled OK. Checked flow through pipe/gate valve from loft tank to HW cylinder - OK. Said pipes from cylinder to hot taps must be OK as good flow. Worked OK 4 hours then airlocked again!! He came back next morning - pipe at top of cylinder full of air again!! Drained down, checked same things again and both the bottom of cylinder and vent pipe into loft - not blocked. The cylinder is only 14 months old, but he thinks maybe the sacraficial anode (?) has dissolved/it's rubber fixing is rising to the top of the tank and blocking outlet pipe when hot. Some little black bits did come out of hot tap this weekend. Has anyone heard of this problem? Please help, we are just waiting for it to go wrong again/don't know what to do!!
He has diagnosed other (banging) problem as a faulty mid position valve, we are trying to get plumber that fitted that back to replace it.
Thanks for any advice you can give (apart from moving house!).[/quote]
